Mixture for WOT
Old Jan 26, 2005 | 07:28 PM
Closer_2001's Avatar
Default Mixture for WOT
What is the best method to richen/lean the mixture for WOT tuning using HP Tuners? I will be making a few pulls on a DYNO to sort out my current tune.
Old Jan 26, 2005 | 08:00 PM
MNR-0's Avatar
Modify the PE vs RPM table under the Fuel tab. Lower the values to lean it out and increase them for a richer mixture. Optimum mixture is 12.6 AFR but CATS tend to bring that down to around 12.2.
Old Jan 26, 2005 | 08:54 PM
What cells are typically WOT on the PE ?
Duh - Sorry, I read it as VE
Got it.
Old Jan 26, 2005 | 11:21 PM
horist's Avatar
the PE Table only activates in Performance Enrichment mode... so all of them are used when in this condition... make sure you're looking at PE and not VE (The affect of PE on the car is derived from the VE table)
