Need help in St. Louis LS1 Edit
Old Feb 2, 2005 | 10:41 AM
MECKER01's Avatar
Default Need help in St. Louis LS1 Edit
My car has failed emission test twice now. However the guy with the sniffer test that if I clear my code out on OB computer and get rid of the SES light. That he will not have to do the sniffer test since the car is 96 or newer. My SES light is on for the EGR valve. I need some close by in St. Louis to help to eliminate this code with LS1 Edit. Please help I have been driving on expired plates for awhile now.
Old Feb 2, 2005 | 10:56 AM
john shea's Avatar
I think autozone has a code reader that erases for $85.00
I live in hazelwood .What part of st. louis are you living?
john
Old Feb 2, 2005 | 11:06 AM
MECKER01's Avatar
I live in south county, at Autozone I believe that just clears the code but as soon as you start the car up, the SES light come back on within min.
Old Feb 2, 2005 | 11:07 AM
Blue Falcon's Avatar
What year is your car, I have HP Tuners for 98-00 and I live in Arnold, MO
Old Feb 2, 2005 | 11:53 AM
SmokingWS6's Avatar
Looks like 01. What codes do you have? if it failed the obd, it should of passed the sniffer test unless you have a fair amount of mods, no cats ect.
Old Feb 2, 2005 | 12:21 PM
MECKER01's Avatar
I have a 98 Z. Port and polished heads, Comp Cam, Mac headers. So I am not passing the sniffer test.
Old Feb 2, 2005 | 12:27 PM
You have a PM
Old Feb 2, 2005 | 12:28 PM
MECKER01's Avatar
Blue Falcon with a HP Tuner can you delete the code from the OBD to completely elminate the SES light. I am getting 2 codes
P0405
P0160
Yes I can
Old Feb 2, 2005 | 02:31 PM
horist's Avatar
P0160 HO2S Circuit Insufficient Activity Bank 2 Sensor 2 -- can be removed w/out issue... post cat O2 ... however if you still have Cats could indicate a failing cat
P0405 Exhaust Gas Recirculation Sensor A Circuit Low , could be !EGR or a failing EGR ... can be removed w/out performance issues
