Swapping to a T56
Old Feb 5, 2005 | 11:53 AM
Ragtop 99's Avatar
Default Swapping to a T56
All my IAC and idle timing stuff is for an A4 which seems to be different from an M6 car.
I have heads, 228 cam etc. I'm looking for someone to post up some sample IAC and timing settings to give me a decent starting point.
Alternatively, e-mail me an LS1Edit file.
TIA
Old Feb 5, 2005 | 12:24 PM
JNorris's Avatar
Moderator
Try here.
I can read LS1Edit 97-00 files. If you find a flash file and can not read it let me know and I will send you the table data.
http://www.ls1edit.com/filelib/
John
Old Feb 7, 2005 | 09:20 PM
Ragtop 99's Avatar
John:
Thanks. I'd forgotten about that site.
Old Feb 7, 2005 | 11:18 PM
pekkaz's Avatar
Are you going to edit A4 file for M6 use ? I've been wondering how it would work. I guess some tricks would be needed with the park-neutral switch, shift points and solenoid feedback lines to keep pcm on correct timing tables.
Old Feb 8, 2005 | 12:18 PM
Ragtop 99's Avatar
Yes, I'm going to use my PCM as is (no reflash to M6). Just a little wiring for the nuetral safety switch.
No need to do anything with the shift tables. Edit has a switch to tell the PCM if the car is A4 equiped.
