PE/VE table question
Old Feb 6, 2005 | 08:54 PM
ls1 joe's Avatar
Default PE/VE table question
How is the PE table value calculated. I have heard that the PE/RPM table should equal your air fuel at wot. 14.7/PE-RPM which for mostof us N/a is 1.130. If the table is off do you correct it in the higher levels of the VE table (90KPA and higher) ? All in Speed Density
Old Feb 6, 2005 | 09:59 PM
horist's Avatar
Ideally the PE value is supposed to be 14.7/PE value ... but that's assuming that your VE table is accurate at those rpm vs map values... if it's off then WOT fueling will be off too
if the table's off you can guestimate the upper load values, but for 100% accurate WOT you need a wideband... I know I wouldn't feel comfortable running 14.7:1 @ 6000 RPM and 100kpa heh (I don't think my engine would be happy either)
Old Feb 6, 2005 | 10:11 PM
ls1 joe's Avatar
The reason I asked I know that the wot Air fuel is 13.0 from 2500 to 7500, I have verifed this with a wide band and dynojet. The problem is if I back calculate my pe table it does not add up to the 13.0 Air fuel. I don't think that the Air fuel is inaccurate because I had a stand alone WB and the one on the dynojet
Old Feb 6, 2005 | 10:13 PM
txhorns281's Avatar
the AFR production may be what your looking for, but not necessarily what the PCM has commanded it to do. IF this is the case then your VE is off at WOT fueling and needs to be corrected... this goes for all VE fueling values
THe object of tuning the VE is to get it to produce the exact AFR that is asked (commanded) of it
Old Feb 6, 2005 | 10:19 PM
ls1 joe's Avatar
Thanks
