Weird Wideband Readings
Old Feb 8, 2005 | 11:12 AM
Black02SS's Avatar
Default Weird Wideband Readings
I have my VE table dialed in to where it needs to be. I shut the car off and let it sit for about 30 mins. Went out and decided to do a log while I did some errands. I notice that my AFR now is way off. I am running a open loop mafless tune. I have my commanded afr at 14.737 and my actual wideband before the restart was right on. Now, I am seeing about a point higher then what I want. I have verified this with the wideband and I don't know what is causing this problem. How can the car be dialed in and then 30 mins later, be a full point off??
Thanks
Old Feb 8, 2005 | 12:36 PM
wait4me's Avatar
is the wideband maybe not calibrated anymore??
Old Feb 8, 2005 | 01:19 PM
Black02SS's Avatar
This is what appears to be happening. I just did a short log as I left work. For about 3-5 mins of the inital startup, the wideband does this weird ****, after that time, all is good like before. I tried to check and see if it was a temp issue or something else, but nothing seems to cause it.
Old Feb 8, 2005 | 01:22 PM
wait4me's Avatar
hmmm, i wonder what the life span of your sensor is.
Old Feb 8, 2005 | 02:05 PM
Black02SS's Avatar
It is a Bosch Sensor that came with my Zeitronix. It hasn't been used for more then 1500 miles and is always on when I turn the car on. So everytime it is used, it is heated.
