Optimal Map reading in HG for WOT?
Old Feb 11, 2005 | 11:12 AM
92SilverSHO's Avatar
Default Optimal Map reading in HG for WOT?
mine reads around 30hg, is that normal? tried a search, couldnt really come up with anything in regards to this.
thanks!
Old Feb 11, 2005 | 11:14 AM
HumpinSS's Avatar
hook the scanner up to the car and turn the key to the on position and log the map values with the car off. This is atmospheric pressure at the current time. If your WOT values match that then there isnt any restrictions in your intake track and you are getting all the air you can get.
Short answer to your question is yes 30 inhg is good.
Old Feb 11, 2005 | 11:18 AM
i also noticed in the logs, that from about 3500-3700rpm, i was at WOT and the o2s were reading around the 400-500 range, then jumped to .89 and .9. But on the other times i go WOT, its instantly at .89 or so. is that fluke, i get KR also.
Old Feb 11, 2005 | 11:35 AM
HumpinSS's Avatar
When they are in the 400-500 can you tell me what FTC cell you are in? Where are you getting KR WOT or during CL operation?
Old Feb 11, 2005 | 11:56 AM
wait4me's Avatar
might have to UP the pe vs rpm engagement table...
