Smog Check Failure
Old Feb 12, 2005 | 10:01 PM
Robert Chicoine's Avatar
Default Smog Check Failure
Just wondering if any one has any tips for passing smog check after returning a stock program in a 2000 Z-28 with a Hypertech Power Programmer III. The car failed the on board diognostic self check. This has happened in the past, and I just put some more miles on it and it passed, this time it did not work?? Any help would be appreciated, I have to sell the beast so I can get a new C6.
Old Feb 12, 2005 | 10:23 PM
dfe1's Avatar
Try disconnecting the battery for a few minutes to reset the PCM. This should clear any pending codes. You'll have to go through a few start/drive cycles before the PCM is happy with itself. There's really no reason that converting back from HPP to stock should create any problems, but sometimes it does. If all else fails, you may be able to convince the dealer to reflash the PCM for you. Your car is covered by an eight year, 80,000-mile emissions system warranty. With a little persuasion, you should be able to convince the service guy that the self-test failure is covered by the warranty.
Old Feb 12, 2005 | 11:04 PM
Default Thanks dfe1
Great info, your allright!
