Tuner Experts- Help This Strange Problem
Here is the problem:
When I launched the car with the 180 or so Wet shot, on the brake/2step/ etc, the car did the following:
1. THe two step was activated at 3500 RPM, on the brake. When I let off the brake, the car bogged to 2873 RPM's.
2. The timming jumped to 25 Degrees for a split second.
3. The stock 02 voltages dropped to like 120 range.
The histogram shows the MAP to be at 100, and I verified that the timing is set at 20, and it is. Please see the following log, and let me know of your opinions on this. I attached a section of the motor run first, and the nitrous run second.
TIME RPM TP TIMING MAF MAP IAT O2 O2
15:27:30:450 3529 0 100 28 0 20.47 14.22 102 334 256
15:27:30:560 3564 0 100 27.5 0 20.68 14.07 102 252 247
15:27:30:670 3592 0 100 27.5 0 20.69 14.22 102 256 239
15:27:30:780 3614 0 100 27.5 0 20.92 14.22 102 313 247
15:27:30:890 3605 0 100 27.5 0 21.37 14.22 102 321 269
15:27:30:940 3568 0 100 27.5 0 17.67 14.22 102 243 239
15:27:31:050 3572 0 100 27.5 0 17.67 14.22 102 321 269
15:27:31:160 3525 0 100 27.5 0 17.96 14.22 104 282 308
15:27:31:270 3552 0 100 27.5 0 16.87 14.22 104 369 256
15:27:31:380 3556 0 100 27.5 0 19.61 14.07 104 386 265
15:27:31:490 3615 0 100 27.5 0 19.97 14.22 104 352 282
15:27:31:550 3649 0 100 27.5 0 20 14.07 104 373 282
15:27:31:660 3699 0 100 27.5 0 20.45 14.07 104 339 278
15:27:31:770 3791 0 100 27 0 19.93 14.22 104 326 269
15:27:31:880 3828 0 100 27 0 22.65 14.07 104 304 299
15:27:31:990 3945 0 100 27 0 20.9 14.07 104 417 412
15:27:32:100 3967 0 100 27 0 22.43 14.22 104 339 373
15:27:32:150 4053 0 100 27 0 21.67 14.07 104 369 386
15:27:32:260 4075 0 100 27 0 23.04 14.07 104 360 412
16:44:58:960 3479 0 100 20 0 16.58 14.22 136 512 382
16:44:59:070 3409 0 100 20 0 15.27 14.22 136 447 295
16:44:59:180 3473 0 100 20 0 19.65 14.22 136 543 299
16:44:59:290 3549 0 100 20 0 19.82 14.51 136 386 339
16:44:59:400 2873 0 100 25 0 13.28 14.65 136 109 143
16:44:59:450 3223 0 100 25 0 14.26 14.36 136 660 512
16:44:59:560 4316 0 100 20 0 21.15 14.36 136 790 625
16:44:59:670 4698 0 100 20 0 26.02 14.36 136 768 629
16:44:59:780 4854 0 100 20 0 28.28 14.36 136 781 634
16:44:59:890 4921 0 100 20 0 28.39 14.36 135 768 621
