BS3 / Stock gauges - interface
I have looked into the BS3 a few times but am just worried about how I would get through an OBD2 scan with it.....
I dont think u will pass........ i know i will never pass...... good new info guys..... mine will be going in soon.
Kyle
Kyle
As far as the stock computer goes, yes it's primarily running the gauges only..
Kyle
Kyle
I have eliminated the enigne harness to the stock PCM. I left the crank sensor lines intact...so I could tie them in if needed.
Was John Meaney able to change the software to half the pulses per revolution.....my corvette tach runs on 4 pulses per rev.....BS3 is 8 pulses per rev......so I will have the same problem.
Also .....what your telling me is the CAM sensor has nothing to do with the tach signal on the stock PCM to the gauge???
There is a on going debate on the LS2 section of this forum...
Please reply........Can some light and maybe pictures be shed on the Gas Pedal modification for the Cable TB...........
Help is greatly appreciated....
Tom Ulrich
i did the crank synchronize and i reccomend you do. mine was off 4 degrees from the 360 that bs3 starts at. you need a pointer, a piston stop, and a way to measure (degrees on a balancer etc.)
bs3 works fine and the customer service is great.
you should go to the bs3 website and read the instructions to check out its capabilities.
its hard to say sitting here when i wasnt there to see what all you cut out or undid from the factory harness.. and also what is different from a 98 car
if the scanner can read the rpm's then i have to say something else is unhooked with the dash
