Delphi 42# ?
Old Mar 3, 2005 | 02:00 AM
Smitty's Avatar
Question Delphi 42# Injector Scaling ?
I've got a set of Delphi 42lb/hr "009" injectors I want to install but have a few question maybe someone can answer.
I know at our fuel pressure they are rated at 48.83lb/hr,so I'd need to scale the injector flow rate table by 1.87/187%
I've read that in the lower ms ranges these injectors move alot of fuel which could make them a lil troublesome to scale.
For those that have scaled these injectors...
1-Will these injectors need alot work/logging to get scaled out?(PIA)
2-Will I need to work with the injector offset table? If so could you please explain a little.
3-Should I just say fuggit and get SVO 42's.
Using LS1 Edit...these are for the '99 car in sig..Any help/advice would be greatly appreciated.
Tony
