SES Light After Cam Install
Old Mar 11, 2005 | 11:18 AM
THE YAV's Avatar
Default SES Light After Cam Install
Hope you can help me out, I am having problem after my LPE GT 9 cam install (228/588/114) for a check engine light. My PCM was reflashed for a different cam profile (previous 208/580/117 no check engine light). The check engine light came on after the LPE GT 9 cam install, about 400 miles. The code I get is P0107 Low MAP (Manifold absolute pressure low voltage circuit). I have changed the MAP sensor, checked for leaks. I get the check engine light at high engine RPMs 6200+(Rev limmiter 6850), the code always comes up as a Histroy code, comes on the next ingition cycle, only if the RPMs go over 6200+. Has anyone heard of this/ experience this? Do you need to set different parameters for the MAP sensor due to the increased vacuum from the cam?
I have tried to fix the problem myself any advice/help would be appreciated I am getting frustrated.
Thanks for your time and consideration in this matter.
v/r
Steve Yavornitzki
Old Mar 13, 2005 | 04:53 PM
THE YAV's Avatar
To the top
Old Mar 14, 2005 | 01:54 AM
stone4779's Avatar
ttt.....Im curious too....mine doesnt do it but I've only got 100 miles since the cam....never know it might do it, too....
