Wide Band in Stock Sensor Hole
Old Mar 11, 2005 | 01:42 PM
Cal's Avatar
Cal
Default Wide Band in Stock Sensor Hole
Anyone see a problem with taking out one of the stock O2 sensors and putting in the sensor for a wideband monitor? This is to be done just as a check of the WOT AFR, then I'll put the stock one back in. I wonder if I will get a good reading.
Old Mar 11, 2005 | 01:50 PM
12secSS's Avatar
Ideally, that is where you want the WB to be at for proper readings. Just turn off the code for that sensor, you should be good to go.
Old Mar 11, 2005 | 01:52 PM
Cal's Avatar
Cal
Excellent! That's what I will do.
