Predator Wiring
Old Mar 14, 2005 | 12:23 AM
67Firebird455's Avatar
Default Predator Wiring
Please, someone, I need your help. Last night after getting my LT's installed, I start the TA and go to plug in my predator, and I get no power, so I try to yank the cable out of the socket and all I get is 3 wires which were pulled from the actual connector. They are green, white and grey. There are 3 prongs inside the connector after disassembly, and I don't know which ones go to what. I'm assuming the green goes to the long prong that goes way inside of the connector and the white and grey go to the others, if someone could please take their connector apart (4 small phillips) and take a look at which wires are soldered where, I would really appreciate it. Hold the connector facing away from you and read left to right so I can figure out where to solder these things again! Thanks!
Old Mar 14, 2005 | 12:07 PM
2001NBMZ28's Avatar
Took mine apart and it has 8 wires (and 9 pins in the connector) - maybe because mine is one of the first units they came out with? If you don't get an answer I'll call my buddy tonight, he has a newer one.
Old Mar 14, 2005 | 12:37 PM
skippytheloon's Avatar
ODBII and cigarette lighter run off same fuse, if blown predator won't work. Don't have my pred on me to dissect though.
Old Mar 14, 2005 | 10:05 PM
I got it... trial and error... I was able to delete my rear o2 DTC when the SES came on. Thanks for trying guys, I appreciate it!!!
