Questions about EFILive V7/Flash/Scan..
Is it true that you can make real time adjustments to idle like you can with aftermarket systems?
If you do a logging and find a problem area, can you also go to the specific timing/fuel MAPS to at the same time to make changes?
The base package states it comes with two lic. that will be used up as soon as it meets the PCM. Can you keep adding more lic. as needed?
Last questions is; what if a car has been programmed by someone else using LS1 Edit can the EFILive takeover from there or is there any locks that effect it.
Sounds like it is real user friendly!
Yes EFILive will be able to take over after a previous edit tune
I was under the impresion just when flashing did it lock a license?
Ryan
The only time it locks when you program the pcm. Blackbox scanning does not require vin lock.
The thing i like is you can read any pcm without having to actually be vin locked.
I have six licenses with mine.
Bill
OOPS! I am wrong it will log.. I didnt have mine setup properly
John
thanks for the answers. This morning I ready the entire HP Tuners manual. I can't decide if I like that software or the EFI Live!!!!! Both look like they will more then get the job done but will like to know of the real cool differences that would help a tuner just starting out.
Also, the majority of conversation in ls1tech's PCM forum is regarding HP Tuners products.. Plus the forum on the HP Tuners site is also extremely active.
Maybe that will help.
- Keith, HP Tuners
Also, just becuase a product is a sponsor, does that mean it is superior??
- Keith, HP Tuners
Tuning is tuning no matter what the package/software so, no your response prolly wont help since both products are on the same level. The only reason Tuners is talked about more on this site is because Live was released in Jan 05 and Tuners has more than a year of being released thus capturing a greater customer base.
IMO EFILive has long since been the best LS1 scanner out there.
John
