Errors in HP Tuners??? Can someone explain why...
Old Mar 20, 2005 | 08:50 PM
Black02SS's Avatar
Default Errors in HP Tuners??? Can someone explain why...
Can anyone explain this to me?? I understand that the data integrity isn't implimented, but "should" be in 2.0, but how much of this "bad" data is going to effect our tune?
Old Mar 20, 2005 | 10:08 PM
WS6snake-eater's Avatar
dude its just a dropped frame....you will get that with every scanner out there. that's why you should always review your data before using it to apply changes. if you are having a lot of problems with dropped frames perhaps you could try logging less pids.
Old Mar 20, 2005 | 10:09 PM
Magnus's Avatar
LS1TECH Sponsor
The chart clearly shows its a dropped frame.
It must be nice to be able to view all of those screens at the same time.
Old Mar 20, 2005 | 10:35 PM
Black02SS's Avatar
How is the first screen shot a dropped frame?
Old Mar 20, 2005 | 10:37 PM
Magnus's Avatar
LS1TECH Sponsor
The first one is not a dropped frame, the histogram is just off by 1 frame..
Send me your log and the frame # and I'll check it out.
I can assure you the histogram is accurate. I use it all the time to tune my car.
