Can 2 different handhelds work together?
Old Mar 23, 2005 | 08:24 PM
nuzee's Avatar
Default Can 2 different handhelds work together?
Would a HPP3 still be able to adjust shift points if the pcm
has a canned Diablo or Crane tune installed in it? Thanks for all replies!
Old Mar 24, 2005 | 05:46 PM
nuzee's Avatar
Anybody? Please.
Old Mar 24, 2005 | 07:21 PM
mrr23's Avatar
nope. one might overwrite another's particular part of the program. or take it back to stock tables. or might lock up your PCM to where you can't get back in. each one also might encript it own lock code. then, the others cannot decode it.
Old Mar 24, 2005 | 08:25 PM
nuzee's Avatar
Thanks for the reply.
mrr23, if that Vinci programmer had the ability to change shift points like an HPP3 or Diablo, it would make it the ideal handheld. Could you suggest that change to Vinci?
Old Mar 24, 2005 | 08:29 PM
mrr23's Avatar
have. major changes are on the back burner. they have been concentrating on the 97-98 folks (so close you can taste it. have two here in orlando testing them now) and the 05 ls2 stuff. personally, i think it's too small of a difference to use that. but maybe for large converters, it would help. but, it is on the list. along but don't hold your with changes in shift firmness based on stock covnerter and higher stall converters. don't hold your breath on it major changes for a while.
