Cam sensor
Old Mar 25, 2005 | 04:29 PM
LS1Z2800's Avatar
Default Cam sensor
I have a 2000 Z28 A4 with high mileage about 130K, but is a daily driver with virtually no problems. The other day I got an SES for a cam sensor? Anyone knows what this thing is for & what it does. Thanks...
Old Mar 25, 2005 | 05:15 PM
horist's Avatar
it's a sensor in back of the intake manifold that lets the PCM know what position the cam is in... the PCM uses this and the crank position sensor to determine where everything is and to determine when to open the injectors and when to give it spark.
Old Mar 25, 2005 | 07:17 PM
LS1Z2800's Avatar
Thanks.
Old Mar 25, 2005 | 11:05 PM
Green Thunder's Avatar
A little more on camshaft sensors
The Camshaft Position (CMP) sensor is mounted through the top of the engine block at the rear of the valley cover. The CMP sensor works in conjunction with a 1X reluctor wheel on the camshaft. The reluctor wheel is inside the engine immediately in front of the rear cam bearing. The PCM provides a 12 volt power supply to the CMP sensor as well as a ground and a signal circuit.
The CMP sensor determines whether a cylinder is on a firing stroke or on an exhaust stroke. As the camshaft rotates, the reluctor wheel interrupts a magnetic field produced by a magnet within the sensor. The sensors internal circuitry detects this and produces a signal which the PCM reads. The PCM uses this 1X signal in combination with the Crankshaft Position (CKP) sensor 24X signal in order to determine crankshaft position and stroke. This diagnostic monitors for a loss of Camshaft Position sensor signal.
Observe that as long as the PCM receives the Crankshaft Position sensor 24X signal, the engine will start. The PCM can determine top dead center for all cylinders by using the Crankshaft Position sensor 24X signal alone. The Camshaft Position sensor 1X signal is used by the PCM to determine if the cylinder at top dead center is on the firing stroke, or the exhaust stroke. The system attempts synchronization and looks for an increase in engine speed indicating the engine started. If the PCM does not detect an increase in engine speed, the PCM assumes it incorrectly synchronized to the exhaust stroke and re-syncs to the opposite cam position. A slightly longer cranking time may be a symptom of this condition.
Old Mar 26, 2005 | 02:57 PM
LS1Z2800's Avatar
Well stated. Thanks for the response. I had to replace this sensor the other day.
