No drill idle mod throttle position voltage question.
I don't understand how you can open up the TB 2-3% without having a high IAC count, high voltage, and high idle.
The best I could do was open up the TB 1% and now I have a 55 IAC count, and .8voltage. I am in cell 19 at idle. Anything higher than 1% increased my IAC count, voltage, and idle. 3% gave me a 1400idle. Idle is set at 800.
This is what I did-
I turned off the car
Made idle screw adjustment with TPS(lower sensor on TB) unplugged
Turned ign. on and waited 30secs.
Turned off ign. and restored TPS connection
start car and rescan
repeat steps if needed
I couldnt get mine to come down enough while still staying under .6volts, so I just drilled it and now my IAC are about constant 40 (down from 120) and my tps voltage is about .58 so its within range
So then, what is the point of the "no drill mod" if I still need to drill to bring down the TPS voltage?
Interesting.....Since the rivet job I performed, my ltfts at idle and part throttle have been +. Could my .81v, 1% throttle opening, and 55IAC count at idle somehow be making me lean out?
