if IFR table is off will it effect WOT fueling
Old Apr 17, 2005 | 03:43 PM
WS6FirebirdTA00's Avatar
Default if IFR table is off will it effect WOT fueling
im trying to figure out how to enter my fuel injectors into the computer. at WOT there is only a 3% change in the amount of fuel. so does that mean my injecotrs are entered in ok and i should start the VE??
the temperature change changed the airflow value by 3% as well. so coudl this be where my WOT chagne is comming from? and maybe the injectors are in there fine? im just trying to find a good way to get an IFR table since the actual numbers didnt work out. but my WOT is right on par taking into account the chagne in air density and i figure if those are on i may have to redo the VE table because of the new/better injectors
Old Apr 17, 2005 | 09:52 PM
luv2spd's Avatar
The IFR is a global adjustment so yes it will affect wot fueling.
Old Apr 17, 2005 | 10:00 PM
ok then im going to just go by that and assume the VE is off because WOT has no issues and i seem to have a hump in the VE at part throttle conditions, maybe my old injectors sucked
