Will this work?
Old Apr 18, 2005 | 12:32 PM
formula87350's Avatar
Default Will this work?
I recently bought a PCM and predator that is "married" to it from another member. The PCM is from a 99 A4 and I have a 02 M6. Now for some scenerios:
1. Can I install the 99 PCM into my car and have it run fine even though I have an M6?
2. Can I install the 99 PCM, set it back to stock therefore "divorcing" the predator from that PCM and then use it (the predator) on mine?
3. Can I send the 99 PCM somewhere and have them tune it for my 02 M6, or do I need an 02 PCM?
4. Or what else do you guys would be best for my situation?
Thanks, I suck at PCM stuff.
Old Apr 18, 2005 | 12:44 PM
horist's Avatar
99 PCM will set EGR codes since you don't have EGR, you'll be running lean since 99 have 26lb injectors and 02 have 28lb injectors...
You'd be better off paying hte 75 bux to have the Predator reset ...
Unless you get THE actual PCM the predator is locked to now you'll be stuck paying 75 bux to have it unlocked anyways....
