question about dynamic airflow, SD tune
so if the trims are off, i adjust the fueling in the VE.... then the dynamic airflow reading will change right? for a certain rpm and map and what not.
im just trying to figure out, if im in SD, and i change the VE table and the PE table based on the temperature change, everything should fall back into line, right?
trying to figure out that idle stuff in the other thread so if my fuel trims arent zeroed in then the dynamic airflow reading is worthless right?
