How to add a pin to the PCM connector?
Old Apr 25, 2005 | 08:34 AM
gomer's Avatar
Default How to add a pin to the PCM connector?
I've completed a A6 to M6 conversion for a guy and everything went pretty smoothly. Except for connecting up the Reverse lockout solenoid. I have to connect it to the lt green wire from the red connector at position #44.. BUT, on an A4 wiring harness that place is blank, no pin or wire there. Is there a pin that can be slid down into the plug and a wire soldered to it?? Please let me know ASAP!
Thanks
Old Apr 25, 2005 | 10:12 AM
FILE's Avatar
Thanks
Get a stock pin out from from the wiring harness from a junk yard. You can push it in with straight paper clip. I had to do when I installed my e-fans.
