Idle problem after disconnecting battery
Old Apr 26, 2005 | 11:04 AM
SLPSS01's Avatar
Default Idle problem after disconnecting battery
I had my battery disconnected for 4 months while the car was in storage.
When I reconnected it the car did not want to idle and died but after starting it up a second time fired right up and was fine. I figured this was due to the fact the car had not been started in 4 months. I've disconnected the battery twice since then and again just this past weekend when installed headers. After re-connecting the battery eachtime it did the same thing, wouldn't idle and died but was fine upon restarting. This never happened before it went into storage. Any idea what could be causing this ? Is my IAC bad ?
Old Apr 26, 2005 | 12:04 PM
01ArcticSS's Avatar
My car did the same thing a week ago (replaced a knock sensor).
I believe that when you disconnect the battery then restart, the car has to "learn" how to idle again. I think i read somewhere that you let it idle for 15 minutes or so then drive it and let it "learn" how to run properly - do some cruising, some part throttle runs and some WOT runs.
Ya know, just for another excuse to go cruising, I might accidentally disconnect my battery tonight!!
Old Apr 26, 2005 | 04:41 PM
black_ws6's Avatar
That happened to me during an indoor weekend car show where you had to disconnect the battery. I couldn't idle at all without stalling. I kept to car running for about 10 minutes and it was fine. Seems pretty normal.
Old Apr 26, 2005 | 04:44 PM
Predator's Avatar
Exactly, idle relearn, and it is normal.
Old Apr 27, 2005 | 11:07 AM
SLPSS01's Avatar
Makes sense. Thanks.
Wierd thing is last summer I had disconnected it a couple times and it never did this before.
Old Apr 27, 2005 | 11:10 AM
SSpdDmon's Avatar
Mine just did it a couple weeks ago right after the SFC's were welded on. Freaked me out for a minute. Thought the MIG fried my PCM or something...
Old Apr 27, 2005 | 03:07 PM
hc_performance's Avatar
I believe I read somewhere that the computers in our cars are only 17mhz computers so it make take a little while for the computer to relearn every thing that was erased.
