Fans low/hi, what temp to kick on?
What temp are you guys kicking on the low and hi speeds fans on? I did a little searching but didn't find any info specific to fan engagement vs. temp so I was wondering what the status quo for optimal performance. The options I have are:
First Stage Fan On Temp - Over Speed =104.0 C
First Stage Fan On Temp - Under Speed =108.0 C
Second Stage Fan On Temp - Under Speed =112.0 C
Second Stage Fan On Temp - Over Speed =108.5C
Not sure about Over/Under speed though?? Any clarifications?
I just use the settings from the hypertech webpage for a 160*(F) stat which I run...which are:
Fan 1 on/off at: 184°F/175°F
Fan 2 on/off at: 194°F/185°F
If I had a programming tool (a real one), I would probably adjust the fans to come on a hair sooner than that (maybe 2°F, but that's just a matter of personal opinion.
Your settings (converted to Farenheit so I can understand them):
First Stage Fan (Off) Temp - Over Speed =219.2 F
First Stage Fan On Temp - Under Speed =226.4 F
Second Stage Fan On Temp - Under Speed =233.6 F
Second Stage Fan (Off) Temp - Over Speed =227.3F
which is pretty much the stock settings (or close)....
If I were you I would try the on/off temps from hypertech webpage as a beginning point and go from there; they use a more aggressive on/off than stock for their power tuning on a regular stat (which I am still assuming you have):
Fan 1 on/off at: 209°F/200°F
Fan 2 on/off at: 219°F/210°F
