Problem with HPT Scanner
Old Apr 30, 2005 | 12:12 AM
2xLS1's Avatar
Default Problem with HPT Scanner
Trying to log a 03 5.3 Silverado on the dyno today, with the chart display open, the scanner would disconnect and try to reconnect approx every 5~10 seconds, then eventually just freeze up. Stopping the logging and restarting would not clear the chart as it normally does, but would just start overwriting what was already on the screen. With only the table display active, it would stay connected and work OK. Never had any problems logging any F-bodies. I even logged a 05 Hummer today with no problems. First time I have tried to log a PU Truck though. Using V 1.6.0
Old Apr 30, 2005 | 12:16 AM
seadoo's Avatar
contact Kevin or Chris at HPTuners....they would be able to help you out the fastest
