Predator speedo fix....what is it??
Old May 6, 2005 | 08:27 PM
Rebelord's Avatar
Default Predator speedo fix....what is it??
OK. Heres the deal. I have a 2001 Camaro Z28 Auto with 275/40/17 nittos with 4.10s out back in the pumpkin. I cannot get the speedo to correct itself. I got the Predator due to the fact that I cannot afford LS1 edit or HP tuners. However, from what I have seen from other peoples experience the Predator is good for a car with mild mods like mine. So, if anyone has or knows the fix for the speedo thing. with 4.10s or hell even 3.73s it would be greatly appreciated. I originally had 2.73s in it.
Thank you all in advance. For those of you, i have searched for several days now. Thank you.
William
P.S. If it works, I'll buy ya a 30pack.
Old May 7, 2005 | 09:12 AM
2001NBMZ28's Avatar
Here ya go - www.runninwiththedevil.com/faq.htm
Old May 7, 2005 | 09:19 AM
2001NBMZ28's Avatar
Almost forgot, after your done you can double check it against the calculator at www.f-body.org/gears/
Old May 8, 2005 | 09:02 PM
Rebelord's Avatar
thanks.
William
