ls1edit? base spark table vs main spark table
Old May 8, 2005 | 12:53 PM
Rays C5's Avatar
Default ls1edit? base spark table vs main spark table
In advancing timing which should be used??? BTW base spark table based on its title in ls1 edit is also closed throttle with an rpm range of 4400!!! Closed!!??
Old May 8, 2005 | 02:30 PM
txhorns281's Avatar
Shortly after you accelerate beyond idle you will be thrown into your main high octane table (or low if in SD mode). So this is where you will want to make WOT timing adjustments.
Old May 8, 2005 | 06:49 PM
Blacker's Avatar
I just used the base spark table to help with start up issues and better cold/hot idling.
Old May 8, 2005 | 07:13 PM
Rays C5's Avatar
That makes sense!!!! thanks
