ATAP users ???
Old May 8, 2005 | 01:03 PM
Rays C5's Avatar
Default ATAP users ???
The ve tables as read with lsedit is entirely different than hptuners. ls1edit has up to 4 digits(xxxxx) where hptuners has 2 or 3 iirc.And neither seems to match up(move decimal?). Also looking at map which is 3 to 4 digits, using atap, how do you determine what map/load range you are in ????
Old May 8, 2005 | 06:42 PM
Blacker's Avatar
There is a conversion from HP Tuners to LS1 Edit if you want to compare the two VE tables.
LS1 Edit VE= (HPT VE)/(5.12/(178.33*0.70819))
As far as map/load, convert the file to CSV and sort. When I had LS1 Edit, this program helped in deriving a VE Table.
http://www.slowcar.net/analyzer/download.html
