Rear O2 codes delete
Old May 9, 2005 | 10:19 AM
mr2guru's Avatar
Default Rear O2 codes delete
I am going to put a wideband in place of one of my rear O2's. I already have P420 deleted as I don't run cats, but what if any, other codes need to be deleted when I unplug and remove the rear O2's?
Thanks and I DID search
Old May 9, 2005 | 12:10 PM
WS6FirebirdTA00's Avatar
i just went through the whole list of trouble codes looking for anything pertaining to rear o2s and shut them all off.
Old May 9, 2005 | 02:08 PM
jay_99z's Avatar
Driver Side
137 - HO2S Circuit Low Voltage Bank 1 Sensor 2
138 - HO2S Circuit High Voltage Bank 1 Sensor 2
140 - HO2S Circuit Insufficient Activity Bank 1 Sensor 2
141 - HO2S Heater Performance Bank 1 Sensor 2
420 - Catalyst System Low Efficiency EDIT:some
people do not have to disable this code, I did, results will vary.
Passenger Side
157 - HO2S Circuit Low Voltage Bank 2 Sensor 2
158 - HO2S Circuit High Voltage Bank 2 Sensor 2
160 - HO2S Circuit Insufficient Activity Bank 2 Sensor 2
161 - HO2S Heater Performance Bank 2 Sensor 2
430 - Catalyst System Low Efficiency Bank 2 EDIT:some
http://www.hptuners.com/forum/YaBB.p...1785;start=0#0
