New to HPtuners, Quick question.
Thanks,
Vann
This is also in the HPT manual.
To read PCM: Key in Run position , 10 seconds for a full PCM boot, then use flash to read it
To Write PCM: Key in run position, car off, 10 seconds for a full PCM boot, then use flash to write it.
If you try flashing or reading w/the car on it'll tell you you can't do it w/the car running (which makes sense... when you flash the PCM you're essentially erasing a portion of it first, then rewriting it... the car needs this portion to maintain an idle and to know when to add spark and fuel etc...)
sounds right
When any of hte HPT software is open press F1 , the manual is a windows help file.
Generally when I'm tuning, I'll have the car scanning... drive arolund a bit, then disconnect the scanner (via the software), make changes to my .bin file, then write the flash, then reconnect the scanner ...
Thanks,
Vann
Thanks,
Vann
just go to file , Write VCM, select a .bin and you're set... the write entire VCM should only be used under certain situations (such as changing the OS of the PCM)... most people never need to use this
