Did LS6 swap now throwing a code??????
Old May 14, 2005 | 10:24 PM
screamin chicken
Guest
Posts: n/a
Default Did LS6 swap now throwing a code??????
I did the LS6 swap about 3 weeks ago now I keep throwing a Map/Baro code p1009.I have checked my plug in and the vaccum line behind the intake, what else should I look for......Also my traction control turns it's off after I crank and the button has no control....
Old May 15, 2005 | 11:05 AM
NoGo's Avatar
Might want to check your grounds. Improperly landed grounds (like the ones on the back of the head and at the base of the block) can cause some funky electrical stuff to happen. Try pulling and landing your grounds again. Additionally, split your grounds up. If you have 3 on the same bolt at the back of the head split them up.
Old May 15, 2005 | 11:54 AM
screamin chicken
Guest
Posts: n/a
Thanks for the info, I did not move any of the grounds.....
Old May 15, 2005 | 03:02 PM
screamin chicken
Guest
Posts: n/a
I found out that one of the wires came out of my plug behind the intake,now I have to figure how to fix it....
