throwing 2 p1416 codes. need a lil help
Old May 21, 2005 | 04:25 PM
00Streak's Avatar
Default throwing 2 p1416 codes. need a lil help
So far ive learned that this is the AIR system. p1415 is bank 1 and p1416 is bank 2.. so where is bank 2? and why am i throwing 2 p1416 codes? will this problem be electrical? could this all be caused from disconnecting connectors without having the battery disconnected? also how can i reset my pcm to see if they show back up. for a while this problem was hit and miss. ses would come off, then mysteriously go off. now its ben on 3 months total. hell maybe longer.
Old May 21, 2005 | 04:48 PM
405HP_Z06's Avatar
Check out this link:
http://www.gearchatter.com/viewtopic8965.php
It should help you chase down the issue.
Old May 22, 2005 | 03:39 AM
CrazeD_SS's Avatar
No it's getting two codes because the condition had been set twice.
The SES light only comes on after the PCM detects the P1416 fault after the second time. I had this same problem. The dealer replaced the AIR check valve and tube and the light hasnt been back..
Old May 23, 2005 | 10:12 AM
00Streak's Avatar
thats what im working on.. finding the dam check valve at a parts store.. been to 2 placed so far and no one has the part.....
Old May 23, 2005 | 10:28 AM
Hooper's Avatar
That's a dealership part.
Old Jun 23, 2005 | 12:12 AM
99whitetranny's Avatar
if i drive my T/A WITH P1416 CODE is it going to mess anything up?
