Question: Not sure where to post
Old May 27, 2005 | 12:05 AM
Swang's Avatar
From: Hometown:Mount Carmel, IL Current: Las Vegas, NV
Default Question: Not sure where to post
well i got an issue, nothing major just happens sometimes and wasnt sure where to post it. well...i got my 2000 SS M6 and when i punch in the clutch sometimes , ill be cruising at barely 1200 rpms and punch in the clutch and the car revs itself up to like 1600? i know its not normal, and im wondering if anyone knows why it does it. othertimes ill punch in the clutch at 2k and itll drop to 1600 and stay there til i get below 10 mph. but most of the time it does like it should. drops to about a grand to 1100 whenever i push the clutch in...any suggestions, or tell me what it might be?
Old May 27, 2005 | 04:01 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Are he mods in your sig all you have done?
Old May 27, 2005 | 08:55 AM
NoGo's Avatar
If you have had your car tuned, then the running air tables are high, or the throttle cracker settings aren't proper.
If you haven't had your car tuned yet then most likely it is a vacuum leak.
Old May 27, 2005 | 12:10 PM
Swang's Avatar
thanks...ill have it checked...yeah, the mods in the sig are it. no tune done. it only does it sometimes...i wish it would do it all the time ya know, so i could find the problem, cuz when i get it on a lift or hook it up, it acts fine...gay!
Old May 29, 2005 | 12:02 AM
A 2000 SS in Jersey's Avatar
Dont suppose its something simple, like you have cruise on when that happens do you???
Cruise does that for just a sec........before it turns itself off.
Have fun
Old May 29, 2005 | 04:40 PM
racinbird's Avatar
It could just be because when you push the clutch pedal down you are removing ALL load from the engine, this could make the RPM raise because it no longer has to use power to turn any pieces in the tranny and cluth, ie gears and snycros
Old May 30, 2005 | 12:28 AM
Swang's Avatar
regretfully not jersey...thanks racinbird...that makes me feel a little better...ill check it for a vacuum leak though just as precaution but you did ease my consciounse
