Need Help
Old May 31, 2005 | 10:33 AM
texasuperman's Avatar
Default Need Help
My car keeps coding and saying its the tps sensor however each time a change it i have the same problem. When im driving ill accelerate and the car wont respond right and then when i let off the gas it will rev up by itself. Also when the car is just idiling it will rev itself up. It also feels like im losing a lot of power. any suggestions would be appreciated.
Old May 31, 2005 | 11:07 AM
horist's Avatar
do you have access to any scanning software? If so monitor the TPS voltage ... should be about .57 w/no throttle... 4.4x to 4.7x at WOT
which TPS codes are you setting? P0121?
Old May 31, 2005 | 02:52 PM
im taking it in to a shop for them to scan it. i forget the code # it is throwing i think it was a p0122
