help with hptuners ordering
I want to order HP Tuners to start learning and tuning my 2000 Z28, but I'm confused about how it works (price wise).
@ HP Tuners site says..
2 Vehicle Types $499
Enhanced IO Interface $150
Do i have to order 2 vehicle types? Sorry if this sounds dumb but i can't get it.
Kevin
It also gives you 2 programmable outputs... so you can activate a relay if TPS = 100% or if RPM > 3000 , etc... you can send the outputs to ground when certain parameters are met as configured in the scanner.
And above is also correct.. you have to choose 2 vehicle types (so if you picked a 99 V8 F-Body you can modify ANY 99 V8 F=Body... same goes for whatever other license you pick)
