Tuning idle? hard for the pro's??
The mods you have are nearly indentical to some of the prepackaged tunes that come free with the Vinci. Just upload (flash and then fine tune if needed)
http://www.vincihighperformance.com/...FO%20PAGE.HTML
However, if you plan to upgrade or do more extensive mods such as a higher stall TQ or Turbo or SC, then the Vinci won't meet your needs.
Find a friend with a laptop. That will save you about $300 - $400.
I don't know much, but I would think you need to be able to get a A/F reading to be accurate
Aaron.
where in nc is that? i live over by charlotte
Someone that can really tune can get all that in 1 visit.When you do all different type's of setup's and really spend your time on them you figure out the basics on each car.Yes,some cars can be harder than other's but that is a real tuners job to figure out.
Our shop does not do the "put the car on the dyno and make a few adjustments"-send them on there way.I alway's run the car on the street and adjust whatever needs to make it run 100% before it even touches the dyno.
Let's keep in mind that someone like myself has spent 100's of hours on the street with scanners hooked up,trying different things and even spend a ton of time at the track to find out what kind of tuning works best.
You guy's can make it like tuners cost way too much -or-won't tune your car right but there are tuner's out there that could be worth the $$
..and slowhawk is one of them
About 95% of the time it is because a customer changed something to there setup.Thats why I offer no charge on changes for a year except dyno time if needed
Now,relieze stockish cars like your's are extremely simple to tune.Alot of 10 second cars take alot longer to tune and I keep/drive the cars to make sure they are 100% and alot of times I even go to a track rental with them to get the most out of it.Another point on tuning is that alot of F-body owners just don't have the time to log everyday and would rather have someone else do it.Not everyone want's to get so technical on tuning
hmmm... when you said hard to tune i **** my pants cause that is exactically what i have in my A4....
I have some logs and tunes that id like you to take a look at if you have the time... me and horist have been bustin our ***** on my car...
Tyler
thanks
