PCM Gasket Question
Old Jun 11, 2005 | 02:53 PM
Johnny5's Avatar
Default PCM Gasket Question
I was putting in a shift light a few weeks ago and instead of pulling the cover off I actually took out one of the harneses from the PCM. In the process the gasket pulled up and off the PCM just a bit. I set it back as best as I could but it is a problem if it isn't on there absolutely perfect??
Car doesn't see rain and I bag the PCM during any engine washing.
TIA,
- john
Old Jun 14, 2005 | 07:09 PM
John_D.'s Avatar
It probably pressed back into place when you tightened the bolt back down.
I was thinking the gasket is in the socket on the harness side. Or maybe it's different on my 98.
Old Jun 14, 2005 | 07:24 PM
calongo_SS's Avatar
It's nearly impossible to get it perfect if you put the gasket on the pcm. Turn the harness over and put it on that side and it will make a nice seal when you tighten it down.
