PE table increase when MAF re-enabled?
Why did my LTFT histogram increase (most cells went to ~10) when I re-enabled the MAF, after tuning in SD mode?
I had identical low and high octane spark tables while monitoring LTFT and changing the VE table. I had the VE table pretty much set (most LTFT near 0), then re-enabled the MAF. When I did, I seem to get more power, but my trims are now off.
My first thought is that my MAF needs re-calibrating, but then I realize that both modes are being tuned by the O2 sensors... so that makes me think something else is going on... like the engine is "allowed" to produce more power in MAF mode, and is calling for more fuel. (this might be the case if the spark tables were different... but they are not)
Please give me a clue.
Dougie
