Help with Trans tuning!
I have a 98 camaro with a 4L60E, it is a stage 3 build from Coan racing. Here is my problem, when I am at the track and launch the car from a complete stop as soon as it shifts into 3rd gear it bogs down like it is pulling timing or something. I took all of the torque management out of it and it still does it. Unless there is something that I am missing. It only does it at the track, if I am on the street and punch it in 2nd at about 40 mph and shift it into 3rd it shifts perfectly fine. Any help or info would be appreciated, thanks Mike.
I don't have a log of it at this moment, but I am going to have one next time I go to the track. Are those things you guys talk about in the trans section or engine section on edit? And when you say disable do you mean just turn it off or set everything to zero? Haven't really looked at it that much. Thanks Mike
I never thought that it could be the converter, but it does make sense though. I never thought that because I thought that the converter wouldn't lock up in WOT. I will have to try that. Thanks for the help guys. Mike
Originally Posted by 02sierraz71_5.3
torque converter is locking whenever your shifting into 3rd at that mph
just set the 100 tps cell in third under tcc properties to 256 problem solved
Thats only on the trucks. On an fbody, anything over 80% tps for 3rd gear lockup is 256mph. so that can't be the problem.
Originally Posted by Bad30th
Make sure you disable engine abuse mode as well as torque management and trans abuse mode...
Bad30th
Bad30th
Any else need to be taken care of?
