Using HP Tuners to tune out Codes
Old Jun 24, 2005 | 05:12 PM
Chevy4Life's Avatar
Default Using HP Tuners to tune out Codes
Ok it's emissions time and i need to take my car to DEQ. My tuner tried once to delete the codes using HP tuners but obviously it wasn't right. Could anyone give me a step by step way of Tuning out the AIR, EGR, and Rear o2 sensors using HP Tuners so i can pass emissions?! THanx
Old Jun 24, 2005 | 05:44 PM
horist's Avatar
go to the Engine DTCs
Find the ones related to the sensors you don't have (EGR, AIR, and Bank 1 and 2 sensor 2)
Set it to "Does not report error"
and that's it...
did this on my car a month ago and passed emissions flying colors
Old Jun 24, 2005 | 06:13 PM
98 Speed Trap's Avatar
In Oregon???
I thought emissions testing was done by a state's DEQ, and they sure as hell don't test down here in Eugene.
Old Jun 24, 2005 | 07:38 PM
Chevy4Life's Avatar
well they Test in Portland....
Old Jun 24, 2005 | 07:39 PM
Chevy4Life's Avatar
and horist ur sure it wont give me a bunch of unready's? Will they eventually become ready?
Old Jun 24, 2005 | 09:21 PM
Another_User's Avatar
I found that if you disable all the codes related to AIR and EGR (no error), then the PCM tells HPTuners that their respective tests have passed, which I think would be very beneficial during smog checking.
Old Jun 24, 2005 | 10:50 PM
horist's Avatar
yup, I just did it to my car not long ago.
I disabled all the codes as stated above. Got 3-4 cold starts, 3-4 hot starts and 30 miles driving and all but 1 readiness test passed.
You may want to post up in the local section to see if anyone near you has a scanner that can read readiness tests... also if it's someone w/HP Tuners for your car, if you can get them to read the PCM and verify the changes (or send me the .bin and I can go over it)
Old Jun 24, 2005 | 11:19 PM
MUSTANGEATER's Avatar
and that's it...
Werd I agree, make sure you keep the Ses enabled to on. I know I've seen them get a readiness failure in IL (not sure if it's directly related to that though) I'm going to have to go through my entire file and set all the codes correctly
Old Jun 25, 2005 | 07:19 AM
I set my SES enabled to off and the HPTuners checks check out. Will that be the same as they see during a smog check?
Old Jun 25, 2005 | 10:06 AM
horist's Avatar
yup... so long as the scanner says the readiness tests are completed... that's what the emissions peops will see....
I've heard a few times in the past that you could set the codes to off and it'd still pass... but my first time doing it I just set them to does not set code and it worked so never tried w/setting the codes to off
Old Jun 25, 2005 | 10:58 AM
Gordy M's Avatar
When the OBD3 PCM's are introduced, I was told we would no longer be able to turn off codes. The EPA wants the software to report bypassed codes to report as failures.
Good reason to keep older cars.
Old Jun 25, 2005 | 11:01 AM
Are you guys just using the normal DTC scan to check for the codes? or is there another way to check all the readiness systems?
Floyd.
Old Jun 25, 2005 | 11:31 AM
horist's Avatar
Floyd.
yup, in HPT it's just the DTC scan... at the bottom it shows which tests are complete and which are incomplete
Old Jun 25, 2005 | 09:45 PM
Sweet, thanks appreciate the help.
Old Jun 27, 2005 | 07:08 PM
BriancWS6's Avatar
If that's true that really sucks
