help,,throwing a po106 code
Old Jun 26, 2005 | 06:00 AM
bernard shortt's Avatar
Default help,,throwing a po106 code
just put in trex cam in slp stroker with ported afr heads from tea,pcm for less done the tuning ,but i keep throwing a code when i first start the car po106.what would cause this ,have racetronic 42lb injectors,anyone know a fix?
Old Jun 26, 2005 | 09:25 PM
Silverhawk_02TA's Avatar
Most likely it's intake port reversion from your cam. Comes with the territory. You can desensitize the P0106 code parameters in HPTuner. Or if you're lazy like me you can just disable it altogether.
Old Jun 27, 2005 | 04:29 AM
thanks i just didn't want to do any damage to the engine
