Help Code Thrown
Old Jun 30, 2005 | 08:22 PM
Scully's Avatar
Default Help Code Thrown
today i was driving my car and it threw a code. the code is 1153. it said it was insuffecient switches (bank 2 sensor 1). i think it is talking about the o2 sensor. if it is or if it isn't what is it? what can i do to fix it? thanks.
Old Jun 30, 2005 | 08:54 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Your probley going to need to pick up a new sensor. But I would try switching the sensors around first to see if the ses light goes away or not. It worked for me.
Old Jun 30, 2005 | 08:57 PM
Scully's Avatar
man i appreciate that. we just installed the kooks race lt's a few days ago. is that normal after header install? that you might have to change the o2 sensors?
Old Jun 30, 2005 | 09:17 PM
Lithium's Avatar
Yeah its pretty normal. My ses light went off around 100 or so after the LT's were installed. But after switching them around it went away - well for now anyway.
Old Jul 2, 2005 | 01:48 PM
jmilz28's Avatar
When you switch them, the code will likely come back on the side you moved it to. If/Once it does, just replace the sensor. If the code stays on the same position, you probably have a wiring/connector issue.
