Inspection help
Old Jul 11, 2005 | 11:45 AM
1LSWON's Avatar
Default Inspection help
I have a heads cam LS1. It is failing OBDII inspection with the codes is LS1 edit to type X. Catalyst Not Ready, Evap Not Ready, 2nd Sys Not Ready, O2 Sens Htr Not Ready? What can I do Please Help
Old Jul 11, 2005 | 12:05 PM
HumpinSS's Avatar
Turn off catylst efficiency P0420 and P0430, P0410-418, P0440-449, P01415-1416, P0141 and P0155 and see if the test complete in your scanner
Old Jul 11, 2005 | 12:08 PM
Ben R's Avatar
okay I have now set them all to X, and I had them OFF, but now they are on X and set to ON.
Old Jul 11, 2005 | 12:13 PM
HumpinSS's Avatar
huh what is set to on. YOu need to turn off the codes listed above to off and no mill
Old Jul 11, 2005 | 12:16 PM
1LSWON's Avatar
hold on Ill open up the program
Old Jul 11, 2005 | 12:18 PM
1LSWON's Avatar
Okay "error Mode, Type X = turned off". Then I have "Does error set SES, ON"
Old Jul 11, 2005 | 12:21 PM
HumpinSS's Avatar
And its set like this for all the codes I have listed above?
Old Jul 11, 2005 | 12:41 PM
1LSWON's Avatar
yes it is like that for all of the above codes
Old Jul 11, 2005 | 12:43 PM
1LSWON's Avatar
is that how it should be set to pass the OBDII part of the test?
