HPT A4 Tranny Shift Question
Thanks!
Scott
Horist, do you know what pin that would be on the ECM (Performance Mode)?
There are three modes that you could set to activate,
Also there is a "manual automatic" mode you can set up too.
The normal tables are the only ones you should change, the others are just a waste to time unless you turn on the other modes.
Jes
I used it on my car awhile ago when i was on the street racing scene, I could do killer launches with it taking off in 2nd gear.
The pcm pin number is 31 for the manual mode, but like i said it is not valid unless turned on.
The only tuning software that i know of that this is even available to turn on is efilive's flashscan.
I even mail the correct wire stuff for everyone to plug into the computer when they ask.
Jes Trending Topics
JesThe Best V8 Stories One Small Block at Time
Then just put the pin in the computer, and it gets a ground signal pulse to turn the mode on or off.
Jes
I wisssshhhhh I could Take off in second= No tire spin = Kicking some butt
