A question about HPT Scanner
Old Jul 11, 2005 | 06:36 PM
Pro Mouse's Avatar
Question A question about HPT Scanner
When play back on the play back scale ,where is the actual real time ?The default setting?Thanks
Old Jul 11, 2005 | 08:13 PM
Magnus's Avatar
LS1TECH Sponsor
You can adjust the playback speed in the Options. THere is a slider that you can scroll from slow to fast.
Old Jul 11, 2005 | 10:24 PM
Pro Mouse's Avatar
Yes I do know that.My bad I wasnt clear enough on my question.But what position should the slider be at for the actual run(Like I was full throttle logging)For that speed would I want the slider in the default position ,in the middle?When I was watching my log at the slowest slider position,I was thinking I hope my car isnt that slow(LOL)
Thanks
Old Jul 11, 2005 | 10:37 PM
Magnus's Avatar
LS1TECH Sponsor
Yea, we don't have an actual real time playback speed. This is the first request we've had for that.
Your car will typically log at 10 frames per second.
VCM Suite 2.0 has the playback speed adjuster on the front page so its much easier to get to.
Old Jul 11, 2005 | 10:59 PM
MrXerox's Avatar
Yeah, its getting a copy of it thats the hard part!
Old Jul 12, 2005 | 04:30 PM
Pro Mouse's Avatar
I was Just Curious Magnus,my logs are hard to read even in the slowest mode ,between having to hit play then quickly over to pause just dont get it.I am having a hard time seeing my shift when I hit second gear and at what speed.Will 2.0 be better for this?I hope so....
Old Jul 12, 2005 | 05:33 PM
Magnus's Avatar
LS1TECH Sponsor
Do you use the chart display? I highly recomend using the chart display, it is the most powerful display you will find in ANY product.
Also, contrary to what others may want you to believe, the gauge display (or dash display) is the weakest display you can use.
Just bring up the area that you are concerned in the chart about and mouse over the frames and you will see the #'s change frame by frame.
Old Jul 12, 2005 | 05:51 PM
Pro Mouse's Avatar
I am in Chart Magnus,How do I do this by frames ?So I can look at it frame to frame?
Thanks!
Old Jul 12, 2005 | 05:54 PM
Pro Mouse's Avatar
No Magnus ,I was Wrong I am in Table display.I changed it to Chart Now I see what you mean Thanks again Magnus...
Scott
Old Jul 12, 2005 | 05:56 PM
Magnus's Avatar
LS1TECH Sponsor
Scott, remember how powerful our scanner is. You can view the chart and the table display at the same time.
You do not have to just view only 1 at the same time.
Old Jul 12, 2005 | 06:13 PM
Pro Mouse's Avatar
Thats sweet!I will Have to get use to it.I have used Auto Tap for a longtime.The HPT Scanner is Leaps and Bounds over That
