EFILive/Flashscan Guys - No More MAF Spreadsheets?
Old Jul 15, 2005 | 08:11 AM
Black02SS's Avatar
You will only be able to see the individual points in the dashboard using a scanner/dash. You can go frame by frame where as the MAPS show high/low/average.
Old Jul 15, 2005 | 12:47 PM
TAQuickness's Avatar
Back to the the point at hand - Black - I appreciate your, and everyone elses, efforts.
Fedex and weather permitting, I will be "autotuning" my VE and MAF tables this weekend. I've also started a complete start-to-finish AutoTune document for EFILive/Flashscan. Once I get done with my tune, and proof read the document, I'll post it up.
Old Jul 16, 2005 | 08:01 PM
Bill Bowling's Avatar
Talking
The autotune works great. How are you logging your SD? Do you just drive around like normal or do you need to do anything special are far as stop and go or no WOT,etc?
Bill
Old Jul 16, 2005 | 09:48 PM
Black02SS's Avatar
The way I use the AutoTune feature is as follows. I disable closed loop and change my Open Loop AFR table to 14.63 from 122* up and 70kPa down. From 122* up and 75kPa up the AFR is 12.96. I disable PE by changing all the values to 1.00(14.63) and a MAP to enable of 105. This makes sure PE isn't entered. I then do a log. I have open the MAP with my AutoTune PID and hit as many cells from 800 to 4000 rpms 15-105kPa. I try and get at least over 50-100 cells in each point before I am done. After this, open the log in the scanner. Apply the AutoTune/Ben Filter where it removes data where the TPA moves more then 5% per 100ms. I also enable the "low count" filter in the MAP itself and filter out all data where the value is less then 30. For WOT runs you will need to settle for something in the 10 range unless you want to do numerous WOT pulls. After that I copy the table with labels. Open the Tuner Ve Table and paste by factor with labels. Flash to car and re-do. Auto tune only works when you have a wideband, so don't try it without one. Also, disconnect your MAF from the car before attempting this and make sure the car is at full operating temp.
Old Jul 17, 2005 | 03:48 PM
Cool
Thanks for the info. I have a LC-1 setup with FlashScan AutoTune. It does work great. Can you have numbers over 100 in the VE table? I have a few cells over 100. I did start loging before car was at full operating temp. I will do some more logging on Monday. Does stop and go hurt the numbers?
Bill
Old Jul 17, 2005 | 04:41 PM
HumpinSS's Avatar
max is 500 although no one should go that high. My ve table has values if 118 for the cam i am running
Old Jul 17, 2005 | 04:48 PM
Talking
What cam are you running? I am running a Torquer 233/233 .595 .595 112+2
Bill
Old Jul 17, 2005 | 07:05 PM
Black02SS's Avatar
That is normal if you are seeing at at a high RPM and High MAP. It doesn't really matter when you start the log as you can just add a filter and remove all data where the ECT was below say 178*F. Start and stop driving is fine. That is what you want to be able to hit all of the cells in question. Also make sure you are using the Base Efficiency Numerator Filter. You could just add a filter to exclude all cells with ECT of 178*F and less.
Old Jul 18, 2005 | 11:10 AM
Thumbs up
Thanks. I did check out the filter and it works great.
Bill
Old Jul 18, 2005 | 12:01 PM
Black - Throw me a bone. I can't seem to figure out how to adjust the low cell count filter. Mine wants to hide cell counts of 0.
Old Jul 18, 2005 | 12:16 PM
HumpinSS's Avatar
edit the map properties and click on the empty cells tab
Old Jul 18, 2005 | 01:25 PM
  #32
MeentSS02's Avatar
Kleeborp the Moderator™
Okay, here's a poser for all y'alls...and this is for those that have Long Tube headers only.
Does anyone else see the inherent problems with tuning your MAF table with a wideband? If you are running in closed loop with the MAF, then you are using narrow band O2 sensors for feedback. In fact, that is pretty much the only feedback your engine has. It is using these to maintain stoich.
So if you are tuning your MAF sensor off of a wideband, you are giving the PCM conflicting information. It is kinda like when I went back to closed loop with my speed density setup. I know the car should be running right at 14.62:1 (since my VE table was spot-on in open loop), but it doesn't. It runs right around 15:1. But the PCM thinks it is running at stoich, because that is the only feedback it is getting (from the narrow band O2s that is).
Anyone have any thoughts on this?
Old Jul 18, 2005 | 01:59 PM
  #33
Duh.
Thanks
Old Jul 18, 2005 | 02:46 PM
  #34
SSpdDmon's Avatar
Don't confuse OL or CL with SD. You can run CL without your MAF and still have feedback from your O2's, which allows you to use fuel trims. That is SD - no MAF.
If you force the car into OL by flooring it or by disabling CL with your software, it can operate with the MAF or without it (SD).
That being said, you can tune the MAF based on LTFT/STFT's for part throttle application where the PCM is commanding stoich. But, you'll need the wideband to tune the MAF for OL situations.
If you're seeing false readings from the NBO2's because you have LT headers, try upgrading your NBO2's to the rear vette O2's. They run a little hotter from what I've read on here.
The only thing that still confuses me is you say you're at 15:1. IIRC, LT headers tend to create a richer AFR due to the O2's being moved further back to a slightly cooler location. If that's the case, you should be seing 14:1, not 15:1. So, I'd suggest double checking your wideband setup. When is the last time you did a free-air calibration? Are you sure the voltage being reported from the sensor is being interperted correctly by your software?
Old Jul 18, 2005 | 02:56 PM
  #35
MeentSS02's Avatar
I'm well aware of the differences between OL SD, CL SD, and CL MAF. My point is, the PCM is getting false readings from the NBO2s. I do have rear vette O2s on there, and they are still errant. I just think it is something that can't really be done well because of the obvious shortcomings of NBO2s when running headers.
I'm pretty happy with my compromise...it runs lean at cruise, but is dead nuts on at WOT. I was happy enough with my results to not consider running a MAF again...I'll just have to keep an eye on my tune as the weather changes.
