Help! Im running lean!!
BTW, have you recently modded without tuning, like headers or intake? If not, you'd have to rule out mechanical problems like air leaks, or anything that might alter your A/F ratio.
Since you haven't done any mods, and the codes appeared, I would check to make sure everything is buttoned up, like exhaust, headers, intake, where the throttle body connects to the intake.
Maybe your car was borderline lean but not lean enough to throw codes, but something changed that put you over the threshold. Go through the car and make sure everything is tight, especially the intake and everything connected to it. Even if that puts you back to where you were (no codes), I would definitely scan the LTFTs and bring them as close to zero as possible. Your LTFTs would have to be over +25 to throw those lean codes.
