having problems with 1993 LT1
Old Jul 29, 2005 | 12:10 PM
night_rider93's Avatar
Question having problems with 1993 LT1
i have a 1993 trans am with a LT1 and it is running like **** it is real hard to start i have to pump it but after i get it started it does want to stay running the idle jumps from bout 1100 to 800 and goes back and forth then when i put it in gear it stalls and it is a automatic i have replaced most of the sensors and new throttle bodie new fuel pressure regulator new fuel filther it has good fuel pressure and once i get it to stay running it acts like it is flooding itself out. can anyone tell me what the hell is wrong with it
Old Jul 29, 2005 | 05:07 PM
KCFormula's Avatar
Sounds like an ignition problem. If you get a Haynes manual it will tell you how to test your ignition with a volt/ohm meter. If it is not your coil the only other thing I could think of is the opti.
