IAC values on a FAST 90mm
First, I never changed any tables in HPTuners to get the IAC counts in line.
Second, I really think you need to verify your IAC motor is even working BEFORE you start worrying about where the numbers are. Seriously, 0 IAC counts at WOT and part throttle does not sound correct.
Regarding the TB sticking, there are threads out there about it, try a search for '90mm stick'. I just did and found you this:
https://ls1tech.com/forums/showthrea...ght=90mm+stick
I'm gonna order a new sensor tomorrow just to confirm whether or not it's the problem. I know I could check the resistance with a multimeter but **** it I'll just get a new one.
I was thinking, you guys think if I drill a hole that there may be a way to bypass the IAC all together? Also if I'm going to drill a hole how big a bit should I start with?
Thanks again guys!
As for bypassing the IAC, yes you can do it but you may find that it's not as smooth to drive while shifting (rpms drop too fast between shifts) and at parking lot speeds (letting off the gas throws you forward). But if you still have the old tb, start with that size hole, I don't remember what size off the top of my head.
Well I run a th400 with a 4200 stall so shifting and the car lunging foward will not be a problem.
What do I have to do to bypass the IAC?
Besides drilling the tb and messing with the set screw so you're getting enough airflow, I think all you'd have to do is delete the error codes it will throw.
As far as what table could cause this, if someone had messed with your IAC vs effective area (putting in numbers that are too big all the way across) then that could keep your iac shut all the time. Also the max desired iac position could do it too i guess. But those can't be it cause you said your desired is 136. I think that rules out a tuning problem.
Did you try your friend's IAC motor on your car? I know you tried yours in his. That would rule out the IAC motor problem.
The only other possibility is wiring, either that or your new tb is machined wrong in a way that doesn't allow the IAC plunger to retract (unlikely).
So should I just disconnect the IAC to bypass it or what?
budchevy358@yahoo.com
also can you summarize whats going on right now, im at work and i dont have much time to read over it all but just hoping i can help you out some. ive been through a lot of different problems when idle tuning and hopefully yours is one of them lol
