help 97 z28 no start no com. with pcm
Old Aug 6, 2005 | 10:51 AM
sick 97's Avatar
Default help 97 z28 no start no com. with pcm
got the car apart put it all back together no spark no fuel no com with pcm checked input to pcm + and - any help thank you
Old Aug 6, 2005 | 11:35 AM
TAQuickness's Avatar
is the battery hooked up?
Old Aug 6, 2005 | 11:44 AM
sick 97's Avatar
yes starter cranks motor
Old Aug 6, 2005 | 11:46 AM
sick 97's Avatar
just checked aldl wires to pcm all good
Old Aug 6, 2005 | 12:04 PM
all the fuses are good? coil packs are plugged in? injectors are pluged in?
Old Aug 6, 2005 | 12:14 PM
sick 97's Avatar
yes yes yes it has msd if i touch white wire to - i have spark
Old Aug 6, 2005 | 12:15 PM
sick 97's Avatar
lt1 only 1 coil
Old Aug 6, 2005 | 12:16 PM
sick 97's Avatar
fuel pump dose go on
Old Aug 6, 2005 | 12:28 PM
horist's Avatar
ok.. so you have spark but no fuel? can you connect to the PCM via the OBDII port? any SES lights?
I'm not very knowledgable about LT1s let me know if you want this moved to the LT1 section of the board ... also have you checked www.lt1tech.com ?
Old Aug 6, 2005 | 01:11 PM
sick 97's Avatar
spark only when msd is jumped no spark on cranking
Old Aug 6, 2005 | 01:24 PM
sick 97's Avatar
yes could u move it 2 lt1 section thanks
Old Aug 6, 2005 | 02:17 PM
I missed that it was an LT1 - I'm not familiar with them either
